04-03-2018, 05:55 PM | #1 |
1931 S/W Fordor Sedan Rear Crossmember
Should a 1931 S/W Fordor Sedan have a metal hump over the Rear Crossmember/spring as part of the floor? It would be under the rear seat cushion.
Thank you for your replies. |
04-03-2018, 07:29 PM | #2 |
Re: 1931 S/W Fordor Sedan Rear Crossmember
No. It was made of a canvas like fabric material, held in place with some thin metal strips and screws.
04-04-2018, 05:55 AM | #3 |
Mine was made from a matching scrap of the original seat upholstery.
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts https://www.fordbarn.com/forum/group.php?groupid=5 |
04-04-2018, 07:32 AM | #4 |
SO, thet's where that COLD draft comes from!! Helps air out backseat farting.
Bill W.
04-04-2018, 07:43 AM | #5 |
I just replaced one and took the stitches out of the original to provide a pattern for making the new. The original material was heavy canvas on the bottom side with a layer of upholstery material (I think seat cover...it had a "pin stripe" pattern). The two layers were held together with a thin layer of tar or black adhesive. The adhesive or tar was so thin it looked as if it had been sprayed on one of the surfaces.
Held in place with thin metal strips sewn into the cover. Short "wood screws" through the thin metal strips and into the metal floor pan secured the assembly. I made mine from two layers of heavy canvas and then sealed the canvas with a melted mixture of 75% bees wax and 25% paraffin wax. Good Day! |
04-04-2018, 09:06 AM | #6 |
There was no cover when I got the car.
04-04-2018, 04:32 PM | #7 |
This is Original
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
04-04-2018, 05:40 PM | #8 |
Here are two photos of the original spring cover on my 1931 160B
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 04-04-2018 at 06:35 PM. |
04-04-2018, 10:17 PM | #9 |
My late '31 is metal attached with similar screws,perhaps aftermarket. Had an early 160B with fabric like the others posted.
04-04-2018, 10:54 PM | #10 |
I've got to find mine, fairly sure it is metal. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
04-05-2018, 01:09 PM | #11 |
Thank you all for the replies. Based on your replies, I found that Bratton's Antique Auto Parts sells a Rear Floor Pan Spring Hump Cover (made from roof material) p/n 35970 and Rear Floor Pan Spring Hump Straps (metal) p/n 35980 for the 1931 Town Sedan. Thanks again.
04-05-2018, 01:18 PM | #12 |
Made my own straps too, used scrap metal that I had sitting around.
cost for me to install the spring cover $0.00. Roof material - free Straps - free Screws - free I don't count my labor because I like working on it so much.
04-05-2018, 06:31 PM | #13 | |
Can't count your own labor, because who would you collect from? |
06-19-2018, 09:25 PM | #14 |
Is that cover actually made from 5 pieces of fabric stitched together?
I never got around to replacing mine, and last winter the opening provided an entry point for mice, who set up a breeding operation behind the back seat. So I need to make one and install it ASAP! Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
06-19-2018, 10:06 PM | #15 |
I once saw some??? car, with a flyweel cover, shaped like that!
Bill Partsjunkieandcollectorofcurbjunk
06-19-2018, 11:16 PM | #16 | |
Yes it is made up of 5 pieces, a rear piece, a front piece and three center pieces from the drivers side to the passengers side. I hope this terminology is clear enough.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 06-19-2018 at 11:52 PM. |
06-20-2018, 05:30 AM | #17 |
Is the fabric from the headliner or the seat upholstery?
06-20-2018, 11:25 AM | #18 |
ours was outside roofing top material (now available long /short grain vinyl)
06-20-2018, 08:32 PM | #19 |
When I recently pulled the rear seat of my 160B I noticed the rear spring was covered with a small braided rug (I didn't think it was original as it had no "Ford" script on it. I looked for the metal cover like my Tudor has - anyhow found out that Ford made the 160 with a piece of canvas covering the hole heal in place with some 1/2" wide 12 guage straps. I drilled out the rusted screws, used 3/4" wide 1/8" thick flat stock steel and a piece of inner tube.
06-21-2018, 04:52 AM | #20 |
I used an old tyre inner tube as it has the correct curveature. 19" tube by memory. Keeps water out. Dave
