Old 06-06-2018, 07:49 PM   #1
josh1331
Default R side directionals stay lit no blink..left ok
Right side light up front and rear but do not blink. Left side blinks fine. I changed bulbs but same results. Cleaned contacts made sure bulbs went in correct. 12 volt system. 57 year.
josh1331 is offline   Reply With Quote
Old 06-06-2018, 07:55 PM   #2
CrownVic55
CrownVic55's Avatar
Default Re: R side directionals stay lit no blink..left ok
Is right side dash indicator bulb lit? All 3 need to work to blink.
CrownVic55 is offline   Reply With Quote
Old 06-06-2018, 09:36 PM   #3
Jwawhite
Jwawhite's Avatar
How about the flasher clicker canister? Sorry, senior moment as to proper name
Jwawhite is offline   Reply With Quote
Old 06-06-2018, 09:53 PM   #4
josh1331
Yes dash light on
Old 06-06-2018, 09:54 PM   #5
josh1331
Yes dash light on
Old 06-06-2018, 09:55 PM   #6
josh1331
I figure if left side works ok the relay is fine? As it doesn’t know left from right , excuse pun
Old 06-06-2018, 10:01 PM   #7
FRANK PKNY
FRANK PKNY's Avatar
One bulb is burnt out, all bulbs need to be good for the flasher to get enough resistance to open and close. Did you replace any bulbs with a LED one? That would cause this to happen.
FRANK PKNY is offline   Reply With Quote
Old 06-06-2018, 10:10 PM   #8
Alaska Jim
Alaska Jim's Avatar
Either one bulb is burnt out, or not making a good ground, or the flasher is bad. these are the 3 things that cause this problem.
Alaska Jim is offline   Reply With Quote
Old 06-06-2018, 10:40 PM   #9
dmsfrr
dmsfrr's Avatar
Just to rule this out if nothing else...
Double check how the turn signal fixtures on that side are mounted to the car and connected to the wiring. There may or may not be a dedicated ground wire from the signal & parking/tail light housing to the car body. Loosen or clean and re-tighten the housing mounting screws to be sure they are making a good ground connection. Or, run some temporary alligator clip ground wires from the housing to the car body.
You'd think if the bulbs light up the ground connection must be good. 98% of the time you'd be right. But if a ground connection has high resistance / poor contact, various strange things can happen.
This (before) photo is of a '55, your '57 may or may not be similar. Notice the headlight has it's own ground wire but the other wires for the turn/parking light fixture do not. It electrically grounds thru its mounting screws. The tail light housings do also.
Old 06-07-2018, 12:24 PM   #10
rotorwrench
rotorwrench's Avatar
It could be a problem in the junction block connection or it could be the turn signal switch too. If the signal stat is working on one side then it should work the other as long as all the lamp connections and bulbs are good. The wiring on all cars that are this old needs to be inspected for condition and all grounds have to be clean & functional.
Old 06-07-2018, 03:23 PM   #11
oldforder
oldforder's Avatar
I would bet on a bad ground. I have found that the socket itself where it mounts to the light housing can lose its contact. Either front or rear will cause both not to flash.
oldforder is offline   Reply With Quote
Old 06-07-2018, 05:08 PM   #12
40cpe
40cpe's Avatar
Did this just happen, or are you working on returning a dormant car to the road? If the sockets were wired wrong, or incorrect bulbs, or bulbs installed wrong so that the dim side is worked by the signals, could be possibilities. It is most probably something on that side that is requiring less amps, not enough to trigger the flasher.
Old 06-07-2018, 06:53 PM   #13
50fordcoupeman
50fordcoupeman's Avatar
I have also had to ground a particular light socket to make it work. As said use alligator clips to ground to test the socket. Good luck.
50fordcoupeman is offline   Reply With Quote
Old 06-07-2018, 07:19 PM   #14
josh1331
Thank you All. I worked on it today it's driving me nuts. First, where is the flasher located and is it two or three prong? Can't find flasher? Would it be in engine compartment?i didn't look yet and book doesn't say where. I found out one thing, the operator book says it takes # 1034 bulbs having 4.6 CP. the 1157 bulbs have 24 cp? So I found one 1034 and one 1157 on the side that doesn't flash. Tomorrow I will look on good side and see what bulbs it has. Might this cause a draw problem ? And not blink. I'm not too savvy on electronics but getting better.i think. I will try the ground effect idea definitely tomorrow. Living alone now I have to split my time up for. Arious duties. In house and yard. Thks again guys I really appreciate it a lot john
Old 06-07-2018, 07:32 PM   #15
40cpe
40cpe's Avatar
Try moving the left side bulbs to the right side.
Old 06-07-2018, 09:22 PM   #16
dmsfrr
dmsfrr's Avatar
... First, where is the flasher located and is it two or three prong? Can't find flasher? Would it be in engine compartment?i didn't look yet and book doesn't say where.
Which model of '57 do you have? It may make a difference? Usually under the driver's side of the dashboard near the steering column. For a shorter wire run to the turn-signal switch wiring.
Not a bad idea.
Old 06-08-2018, 12:03 PM   #17
rotorwrench
The two post signal stat or can type flasher unit is generally a bi-metallic switch that works on the heat generated by the current flow to the signal lights. If current flow is low such as one bulb doesn't function then it may not have enough flow to get the bi-metal hot. If you add more bulbs to the system such as a trailer or higher wattage bulbs then the flash rate will get faster as the current draw increases.
The 3-terminal can type generally has a heater coil to operate the bi-metallic switch so it needs a ground. This type will work even if one bulb goes bad.
Old 06-09-2018, 01:08 AM   #18
KULTULZ
KULTULZ's Avatar
... where is the flasher located and is it two or three prong? Can't find flasher?
Turn the switch to the side that works and follow the click.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 06-13-2018, 02:16 PM   #19
josh1331
DMSFRR. Model 63b
Old 06-13-2018, 02:20 PM   #20
josh1331
Jumped the stop light two wires no stop lights came on but have power at two wires.??? Cleaned all connections. Now going to see if wires are connected right at junction box ear radiator where all light wires are.
