Old 05-05-2018, 09:23 AM   #1
Gnico
Default F.M. Horn Rebuild Kit Question
I have a Model FM Labs horn that most likely needs a new diaphragm. It works but only plays a long ahoo with no ga Not sure if the on line repair parts are the same for all horn models.
I see this kit on Mikes
http://www.mikes-afordable.com/product/A13804RK.html
or Snyders for this part
https://www.snydersantiqueauto.com/h...m-battery-type
Gnico is offline   Reply With Quote
Old 05-05-2018, 12:25 PM   #2
Badpuppy
Default Re: F.M. Horn Rebuild Kit Question
You mean EA Labs model FM. Mike's kit will rebuild most of it but you may need the ratchet too. If the adjustment and lube doesn't work, open it up and see if you can determine the problem. Says "Ah" when the motor spins up, "OO" while it runs, "Gah" when it spins down. Sounds like it just needs a little oil on the felts.
Old 05-05-2018, 08:50 PM   #3
Gnico
Thanks, you are correct on the EA I will try some lube and see if I can get it to work better.
Old 05-06-2018, 08:00 AM   #4
Steve Wastler
Steve Wastler's Avatar
Also Make sure you have the paper gaskets on both sides of diaphragm, makes a huge difference in how it operates
Steve Wastler is offline   Reply With Quote
Old 05-06-2018, 01:07 PM   #5
Ron in Quincy
Ron in Quincy's Avatar
also keep the armature clean. Always use plain fine sandpaper to clean the armature.
the faster the armature turns the better the sound.
some of the replcement diaphrams are junk, the centter contact is poor quality and wears off fast.
keep the felts lube.
ron
Ron in Quincy is offline   Reply With Quote
