05-01-2018, 05:48 PM | #1 |
Helping Get Rid of Sound a Bit
It's been a year since the interior rear panels were removed and they're out again for some welding and new sound/ heat material install---floor
The muffler tips were moved from the rear bumper and positioned out towards the rear sides, behind the wheel. Driving the car with this arrangement has created new humming? Sound from the rear compartment, the deadly muffler drone? Since the panels are off what material can I attach to the inside metal? The car was designed for some water to pass through the rear windows down the interior panels, out the drain holes, so this material has to withstand occasional moisture and not contribute to rust. Suggestions? |
05-01-2018, 06:10 PM | #2 |
Re: Helping Get Rid of Sound a Bit
There’s always dynamat and it’s automotive competitors, but a lot of guys seem to like this type of product from the local big box store. Don’t know who’s close to you, but should be cheaper than this. Generically refered to as peel and stick.
http://buymbs.com/p-113-mfm-peel-sea...iABEgKzLfD_BwE |
05-01-2018, 09:30 PM | #3 | |
I don’t think any of the mats are a good idea on the inside of the quarter panels as there is the risk of holding dirt and dust between them. Personally I would make sure it is completely dry and spray a good quality body deadener in the area. There is always going to be water coming into area from the rear quarter window.
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
05-01-2018, 11:06 PM | #4 |
On my ranch wagon, I attached dynamat to the back side of the side panels.
05-02-2018, 10:16 AM | #5 |
05-02-2018, 12:59 PM | #6 |
Ford did a terrible job of coating the metal in body enclosures so they were vulnerable to corrosion anywhere moisture can get in. It's too bad they didn't make scuppers for the rear windows in those old wagons. With doors, your stuck with the water coming in around the roll down windows. Putting sound deadener on the inner cover panels isn't a bad idea. Keeping the car in the garage during the rainy season is not a bad idea either. Drive the modern throw away cars when it rains. |
05-02-2018, 08:19 PM | #7 |
I found that adding dynamat to the backside of the panels helped a lot in deadening the sound.
05-03-2018, 03:05 PM | #8 |
I've heard that Lowes sells a product that works well, self adhesive, anyone use this?
How about the Fiberglass Evercoat 12"X12" panels? About $7 each! Self adhearing, I don't think they'd hold water... Last edited by Jwawhite; 05-03-2018 at 03:33 PM. |
05-03-2018, 03:48 PM | #9 | ||
for the floors/toe boards (sound and heat insulation) and the above material for the inside of the trim panels. All weather seals have to be good also. Where are your outlet pipes now? Do they extend beyond the body?
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
05-03-2018, 05:45 PM | #10 |
Hi K, the outlets on the quarters and doors are slits perpendicular to the panel bottoms. Further the rear ward slit is pushed up a bit, backward facing funnel. They've been cleaned out in the past with a screwdriver below and from the interior side with panels off.
That rolled roofing is great for roofs, stopping leaks but I'm wondering if there is an odor about it. I've got some great material for the floor, now need something for the vertical wet areas. There is that Evercoat spray deadener product, perhaps a base of that and a few Dynamats around the exhaust area... |
05-03-2018, 06:20 PM | #11 | |
Kinda hard to visualize without being there. I would use and spray (undercoating) sparingly. Do not cover drains or seams designed to carry water. Did the noise begin with just the turn-outs? Properly hung/insulators (the exhaust)? Did you read the entire DYNAMAT auto site? Some new stuff added.
05-03-2018, 08:14 PM | #12 |
The guys that use the peel and seal haven’t complained about odor. Some who’ve used to on the roof above the headliner have had it sag, others are ok, so that’s probably prep related. I used an industrial adhesive rubber/foil product because I’ve got a friend in the business. The other product widely used is “lizard skin”. It’s a paint style product with glass beads or something. Google will bring it up, and well as stuff you can mix in regular paint and apply.
Are you trying to block sound from outside the car, or do you think you’re trying to dampen resonance in the panels themselves? Last edited by miker98038; 05-03-2018 at 08:57 PM. |
05-04-2018, 01:31 AM | #13 |
Hi Mike, I've read about the muffler drone but never experienced it until I changed up the exhaust from out the rear bumper to the sides behind rear wheel. See photo above. So I'm trying to deaden the sound coming in through the rear quarters of the wagon. Currently I'm thinking of combining techniques to cover up the drone. Perhaps padding on the inside of interior panel, spray deadener on inside skin of quarter and a couple of Dynamat squares also on the inside quarter near the exhausts.
