I second Mr. rotorwrench.
For instance, use a Ron Francis Constant Voltage Reducer under the dash to get a consistent 6 volts to your gauges. Also, if your truck uses a voltage gauge, one of the above posts tells how to reduce the incoming 12V so the gauge will still read properly. Last edited by 19Fordy; 04-18-2018 at 06:36 AM. |
