Old 04-13-2018, 10:59 AM   #1
divcoone
divcoone's Avatar
Default Hill and fuel
‘31 loses power on a hill. Turn on electric fuel pump and engine picks up. Switched carbs with a known good one and same problem.
Anybody have any suggestions.
divcoone is offline   Reply With Quote
Old 04-13-2018, 11:25 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Hill and fuel
What's not stock that it needs a fuel pump--- gravity is still working as I write---
Old 04-13-2018, 11:36 AM   #3
divcoone
divcoone's Avatar
Gravity works here also. Electric pump was just an idea that solved the problem.
Old 04-13-2018, 11:42 AM   #4
Jim/GA
Jim/GA's Avatar
Which carburetor are you using?
What, if anything, are you doing with the GAV before the hill and on the hill?
What are you doing with the spark lever before the hill and on the hill?
I suspect that the fuel pump is enrichening the mixture in the carb due to the higher pressure overwhelming the needle valve. The richer mixture is giving you the added power on the hill.
Jim Cannon
"Have a Model A day!"
Old 04-13-2018, 01:00 PM   #5
burner31
burner31's Avatar
Pick a smaller hill?
File Type: jpeg 7bf20e311716c9f6f50cd81baf7a91e6_400x400.jpeg (18.1 KB, 14 views)
Keith
Shawnee OK
'31 SW 160-B
Old 04-13-2018, 02:34 PM   #6
Corley
Seems you have restricted fuel flow. You can see where by pulling the fuel line of the carb, and running fuel into a jar/can, and checking for full flow. If its a weak flow, the problem is between there and the tank. If you have a nice full flow, the issue is in the carb. If the problem is toward the rank, pull the filter bowl and check flow there. I suspect you will find it is a poor flow rate out of the tank, but only a test will confirm.
Just what I'd do...
Corley is offline   Reply With Quote
Old 04-13-2018, 02:40 PM   #7
mfarley
mfarley's Avatar
Sometimes I open the GAV 1/2 turn and pull the spark up one notch just before an uphill climb. Seems to help.
mfarley is offline   Reply With Quote
Old 04-13-2018, 03:04 PM   #8
divcoone
divcoone's Avatar
Thanks for the reply’s. I’ll be back.
Old 04-13-2018, 04:13 PM   #9
Jacksonlll
Jacksonlll's Avatar
That’s a very common problem. Your fuel line is going into carb too far and hitting the screen. Just circumcise it a bit.
Old 04-14-2018, 07:03 AM   #10
captndan
captndan's Avatar
Doesn’t that hurt on a car that old? Should have done that at the dealer.
captndan is offline   Reply With Quote
Old 04-14-2018, 08:01 AM   #11
redmodelt
redmodelt's Avatar
Lol
Old 04-14-2018, 03:09 PM   #12
hardtimes
hardtimes's Avatar
Yeah, suggestion.
Tell us what equipment (for carburation) you are using on this '31 ?
I suspect that 'using a fuel pump' could mean that you are using a downdraft, but we are guessing at that.
Old 04-14-2018, 06:45 PM   #13
divcoone
divcoone's Avatar
No, it’s original Zenith. I’ll post some things later.
Old 04-15-2018, 01:47 AM   #14
hardtimes
hardtimes's Avatar
Interesting. Never have seen or even thought about the use of an electric pump with stock updraft !
The original location of the zenith makes it low enough that gravity was sufficient to handle fuel delivery.
Old 04-15-2018, 02:34 AM   #15
Floats
Floats's Avatar
Might be low float level
Floats is offline   Reply With Quote
Old 04-15-2018, 07:29 AM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
I agree. There must be a plugged line or carb passage if it needs the help of a pump.
Old 04-15-2018, 01:40 PM   #17
rocket1
gas cap not vented,wrong cap?
rocket1 is offline   Reply With Quote
Old 04-15-2018, 02:24 PM   #18
Jacksonlll
Jacksonlll's Avatar
Trim off most of the fuel line that extends beyond the ferrule.
Old 04-15-2018, 06:46 PM   #19
eagle
eagle's Avatar
I would say the only thing the hill is doing is causing it to pull harder, thus using more fuel. There is plenty of gravity as the gas tank is considerabley higher than the carb so the angle of the car on the hill shouldn't be an issue. As others have said, check fuel delivery.
Old 04-15-2018, 08:07 PM   #20
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Do you have an in-line non original fuel filter?
Chuck Sea/Tac is online now   Reply With Quote
