03-12-2018, 03:19 AM | #1 |
USA Light Switch
I've seen conflicting things on the new reproduction switch. What all is exactly needed to get it working correctly? I have a new harness from Bratton's and a new USA switch. I've heard to modify the harness disc, or sand down the metal housing on the switch. Who all is running this setup and what was your experience of getting it to work smoothy?
03-12-2018, 07:51 AM | #2 |
Re: USA Light Switch
Hey Jeff, Assemble the harness and switch, and place on the end of the steering column, before running the wires through the frame. Does the light switch move easily, or at all?
Chances are, you may not have any problem. In the past, I had to file down a new harness wafer/disc as it was thicker then the original, being used in an original switch. Good Luck. Keep us informed of your findings. Jeff D
Let's let pylons, be pylons! |
03-12-2018, 03:58 PM | #3 |
I'm buying a new USA switch this week and I already have a new harness.
Keep us posted.
Isaiah B. 1928 all metal Tudor |
03-12-2018, 08:48 PM | #4 |
Thanks for the replies, I'll probably install them both later this week.
03-13-2018, 02:18 PM | #5 |
03-13-2018, 07:35 PM | #6 |
03-13-2018, 09:48 PM | #7 |
03-14-2018, 07:33 PM | #8 |
great tip! and I thought I was just starting to have a model A figured out and the old dog here learns a new trick! lol Awesome!
They know enough who know to learn. |
