Would anyone have the operating instructions for a Snapon Model No 926 Multimeter? Thanks,
Bob |
Bob
Did you google it? Bruce
Works good Lasts long time |
This is back a while, but might be worth a try. Be careful of some of the "manual download sites" they are basically malware. This was posted in 2015.
"A friend of my gave me his old Snap-On MT926 multi meter but there isn't a manual, and he has forgotten how to use it. I have looked on the net and not found what I am looking for. I will call Snap on but I think they may not support it any more." "I called Snap-on and they emailed me a copy of the manual no issues, so I guess that my belief that they didn't have it was wrong. When the Internet works it's a wonderful thing, but there are plenty of scammers out there." |
Looks like your basic dwell-tach meter. Connect the black to ground and the yellow
to the distributor to coil lead and it should work. For ohms clip the two lead together zero the needle and your good to go. Bob |
Thanks for the replys!
Bob |
There were at least ten cars with five cylinder engines.
https://gearheads.org/10-great-cars-...linder-engine/ Bob |
I have one of those. I will look and see if I still have the manual for it. I have had the meter since the '70's. I worked as a Professional mechanic all my life. I have not seen the manual in years, but I will look when I go out to the shop later today. for dwell and tach functions , the black goes to ground and the other lead goes to the coil.
#9 | |
![]() Quote:
#10 | |
![]() Quote:
Again, all kinds of 5 cylinder radials in airplanes; none in a car. The Adams-Farwell had a ROTARY engine. Look it up. Actually, you should, it is an amazingly weird machine.
#12 | |
![]() Quote:
My only point was that RADIALS and ROTARY engines are two completely different animals, even though they both are ROUND. DD |
#13 |
Thanks everybody! All set!
Bob |
#14 |
Tubman:
I don't have any other leads. However, have it figured out and I'm good to go. Thanks! Bob |
#15 |
Alaska Jim:
I'm all set! Thanks very much! Bob |
#16 |
Bob C
#17 |
Teltruck, I have not located my owners manual yet. Its been about 20 years since I last saw it. I am still going through my stuff ( see what you got me doing now lol. ) I may not have it any more, If I find it I can make a copy and mail it to you. I will know tomorrow for sure whether or not I still have it.---Jim
#18 |
Teltruck, I have finished going through all my toolboxes and file cabinets. I have not come up with the owners manual. I must have lost it over the years changing jobs and moving. I see you say you are good to go. If I do come across it, I will let you know. sorry I could not be of much help.---Jim
