#41 |
bills: I would install them so that the clamp also holds them in place. Use sealant of course.
#42 |
Be a little difficult to operate them without them! The originals were a lower temp (160 I think) because of the types of antifreeze in use. The operating temps were increased over the years to improve efficiency.
Update: The Green Book shows the early thermostats were as low as 140 deg! Last edited by JSeery; 02-21-2018 at 09:14 AM. |
#43 | |
![]() Quote:
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
#44 |
#45 |
#46 |
#47 |
Here's an example of the old ones. Ed
#48 |
I'm not the person to respond to questions about original parts, LOL. That's a question for someone like Dave. Would sure be difficult to drive in northern climates, guess you could block the radiator off. Guess I can read a parts book.
![]() Last edited by JSeery; 02-20-2018 at 10:08 PM. |
#49 | |
![]() Quote:
Yeah, that's why EVERY internal combustion engine manufacturer in the world puts them in...because they are not needed. ![]() |
#50 |
If everything was truly up to snuff in your engine, the operating temperature would never get any where near what is should be. I had a stat stick open on my car and the temperature barely got up to 150. This is with a 276 cu in engine with a stock radiator and no pressure cap. I also have stock water pumps, no "high flow" stuff. Glad it works for you.
#51 |
I tig welded a modern t/state to a short length of stainless exh tube and the just slipped them up in the top hoses.
lawrie |
#52 |
Hey I understand ya gotta work with what ya got. All our Flatty's are old blocks, yea most have been checked for cracks but ya never really know about the cooling internals. Some work great some not so much. Typically we don't find out til it's running in our cars. If ya get it working in the right range and gotta go without stat's to get there you go with it. If ya need an auxiliary electric, go with it. I pretty much run my Flatty only in warmer weather Spring, Summer, early Fall. I currently am running stat's & one side is giving me a PIA not opening half the time and I have to shut down and wack the housing with a big wooden screw driver handle to get it to open then fine till next shut down. Have had issues in the past with stat's sticking. IMO, and from my experience while they work when opening and closing properly great, but my experience is they frequently don't. I've run without & in the warmer weather mine comes up to temp just fine and stays in a nice operating zone ( 175 while at speeds & 200 in slow to stopped traffic. I will probably remove mine before my season begins (again) as I'm sick of seemingly always having some kind of an issue with stat's. A lot is written about Flatty's being cooling challenged.
Nomad |
#53 |
My engine a 53 flathead.It is completely rebuilt,I'll say it again completely rebuilt and far from stock.Even got one of Bubbas 12 volt dizzys in it.I don't know everything about heating and cooling but have been in the plumbing and heating business for 50 years,put in my share of hydronic systems.My engine runs great without stats,course I don't drive the vehicle in the winter.All the gauges are new also.I guess there are those that know or think they know everything,but I'm not one of them.
#54 | |
![]() Quote:
