02-20-2018, 11:08 AM | #21 |
Re: Something wrong
Also be certain to torque in the proper sequence, as described in the Service Bulletins or many other sources.
02-21-2018, 06:37 PM | #22 |
Re: Something wrong
Mechanics at work
It is a pile of shit bit it's my pile of shit |
02-23-2018, 04:55 PM | #23 |
Re: Something wrong
They may be moving but are they closing? Compression test to see. If not that, then it is a blown gasket.
02-24-2018, 01:17 AM | #24 |
Re: Something wrong
All is well again,gasket was blown and is replaced,everything else is checked,oil pan is cleaned out and new oil,new coolant and at the same time the upper water neck replaced because the old one was too thin at one side(0.5 mm).
Yesterday i drove it about 70 km trip and no more problems......Happy again.
02-24-2018, 02:03 AM | #25 |
Re: Something wrong
Great news, now enjoy the spring... when it comes.
02-24-2018, 05:43 AM | #26 |
Re: Something wrong
Only when it is very cold it stays at home,the model A can stand the cold but i don't.......no Heather and a bit drafty make me take a modern car.....oh well,not very modern but a 1985 Citroën Visa.....
02-24-2018, 07:49 AM | #27 |
Re: Something wrong
Head gasket needing to be replaced is really not uncommon. If you own a Model A long enough, it’s going to happen.
Now that the head is off. I would recommend that you have your mechanic check the head to make sure it is true, (flat). Easier now than finding a leak after you get it back together. Enjoy. |
02-24-2018, 01:32 PM | #28 | |
Re: Something wrong
the head was true
02-24-2018, 07:52 PM | #29 |
Re: Something wrong
Be sure to retorted several times. The torque will fall off.
02-25-2018, 01:30 AM | #30 |
Re: Something wrong
02-25-2018, 01:33 AM | #31 |
Re: Something wrong
02-25-2018, 09:39 AM | #32 |
Re: Something wrong
i lost compression on 3 and 4, the head gasket let go between them
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
02-25-2018, 09:42 AM | #33 |
Re: Something wrong
your lucky it took me 3 weeks to get the head off my A
02-25-2018, 11:15 AM | #34 |
Re: Something wrong
03-07-2018, 01:13 AM | #35 |
Re: Something wrong
Rene
If you have original style valves with the mushroomed stems, then 15 thousands should be fine. If you have adjustable valve tappets with modern valves, then I would use I-.10 & E-.13.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
03-07-2018, 01:13 AM | #36 |
Re: Something wrong
Rene
03-07-2018, 09:35 AM | #37 | |
Re: Something wrong
(Business is good, lot's of work)
03-07-2018, 09:48 AM | #38 |
Re: Something wrong
Just a FYI
