Old 02-15-2018, 12:31 PM   #1
Ron52
Default Re: 1930 Brakes
T B lots of slack in the right actuating arm front. To remove all the slack makes the arm straight up and down, however the book calls for 15%. Any comment please anyone..
Ron52 is offline   Reply With Quote
Old 02-15-2018, 12:42 PM   #2
700rpm
700rpm's Avatar
Have you read Andrews’s chapter on brakes in his red book yet? You said you had it, I believe. Many of your questions are addressed there, along with step by step instructions.
Ray Horton, Portland, OR
Old 02-15-2018, 01:21 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
If the rods are worn down, then I'd buy new ones.
That's all it took to make my levers slant forward at 15*.
1 or 2 pills in the wedge can also make the lever slant forward.
