Old 02-08-2018, 09:13 PM   #7
Dick Webber
Default Re: 49 Mercury overdrive transmission assembly question
Wow! That is a real pretty transmission!
To clarify:
I am testing this unit with the overdrive lever in the lockout position, no solenoid attached, shifting cover off, and out of car. I made a tool to pull the balk ring out and I believe it is in position where I could attach the solenoid
The final drive does not freewheel and the unit works fine in second and neutral.
I am not in 2 gears at once
To test the overdrive for freewheeling I engaged the lockout lever and the output shift will freewheel.
The baffling thing is, if it turns in neutral and second, why doesn't high work? It's not stuck as the main drive will turn, but only a few degrees.
I'm going to try another synchronizer but even if it fixes high that doesn't explain low and reverse.
The cluster is 28-24-16-14 with a 16 tooth main and 29 tooth slider. I hope I remember this right. Notes are at the shop. It all turns smooth in neutral.
And if the synchro change doesn't work I have a conventional tail housing I can install to isolate a possible overdrive problem.
Thank you all for your ideas.
Dick Webber is offline   Reply With Quote
