Old 02-08-2018, 12:31 PM   #1
oldforder
oldforder's Avatar
Default greasing the clutch shaft/throw out bearing.
Figured since I just got this car (29 Tudor) that I should grease and oil everything. It kinda looks like most everything has been greased lately, but I am going over it all again, so I KNOW it has been done. I figured that the clutch splines hadn't been done for probably a long time, but I don't know how many pumps from a grease gun I should give it.
oldforder is offline   Reply With Quote
Old 02-08-2018, 12:35 PM   #2
Jim Brierley
Default Re: greasing the clutch shaft/throw out bearing.
Don't grease the splines, it will cause the clutch to slip or grab, also the T.O. brg. doesn't need any.
Old 02-08-2018, 12:42 PM   #3
oldforder
oldforder's Avatar
There is a zerk there and the "book" says to grease it every 2000 miles.
Old 02-08-2018, 12:53 PM   #4
BillCNC
BillCNC's Avatar
How's that, are you saying excessive grease flying around or any grease at all?
I have alway's rubbed grease on the splines in other cars, but I always wipe 80% of it back off. I started doing this back in the 70's because a few trany splines I've had before looked pretty dry and galled.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 02-08-2018, 12:54 PM   #5
100IH
The original T/O bearings had a pathway for the grease to get to the interior of the bearing but not the shaft splines for good reason. Most or all newer bearings are sealed with no pathway to the bearing. You'd only be greasing the sliding carrier for the T/O bearing and it probably is not a big issue. Too much grease there would/ could become an issue.
100IH is offline   Reply With Quote
Old 02-08-2018, 01:08 PM   #6
oldforder
oldforder's Avatar
Ok, I gave it a couple pumps, and will button it back up and call it good for a couple years at least, as I will put very few miles on it.
Old 02-08-2018, 01:14 PM   #7
1930-Pickup
Don't forget that many books and lube charts were written a long time ago. Lubes are much better today than in 1930, so the 're-lube' or 'change' interval can be significantly extended past the numbers you read.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 02-09-2018, 01:09 PM   #8
Jim Brierley
Being rather on the thrifty side, I have never bought a new T.O. bearing. When I have the engine or trans out I remove the bearing from the collar it's mounted on, clean the outside thoroughly, force grease into the bearing by using a wheel brg. packer, and re-install. Good as new!
Old 02-09-2018, 04:12 PM   #9
Ed in Maine
While you are at it, use the correct grease for the water pump and do not put too much into it because you will load up your radiator. I personally do not lubricate the rear bushing while the pump is on the car but I do remove the water pump, grease it and remove any excess and reinstall the pump. Ed
