Originally Posted by Solo_909
I ran a search and couldn’t find much on common rear axles used for swapping out the banjo rear end. My banjo is leaking pretty bad so time for an upgrade.
Side question, can the rear wishbone be used on the newer axle? I’m not really interested in running parralle leafs.
Thanks!
ANY complete banjo rear end, spring and torque tube included, will virtually bolt-in to your '35. All of the important dimensions are the same, '35-'40.
Your rear wishbones will only bolt-up to '35 and '36 axle bells. DD
