Old 01-24-2018, 12:23 PM   #3
3.6rs
3.6rs's Avatar
Default Re: Question on the safety switch?
Originally Posted by gypsycandle View Post
If the safety switch is installed so that the case of the switch touches the frame, does that create a ground and nullify the purpose of the switch?? I know it is a switch in the positive side (which is ground in the Mod A) but if it touches a ground , what happens electrically? Thanks in advance.
If you want to cut off the positive ( model A ground) and this touches the ground (so, the positive) there will be NO cut off. As simple as that.
But why installing a cut off switch that is n,ot isulated ? That is the question...
3.6rs is offline   Reply With Quote
