Old 01-11-2018, 10:19 PM   #1
Leatherback 57
Leatherback 57's Avatar
Default 2 Blade Fan
Im changing from a 4 blade to a 2 blade after doing valve job. I bought the fan from Snyders. Has anybody bought one from them? Mine came with what looks like a crack and casting flaw that is powder coated over. Is this normal for a recasting assy.
Leatherback 57 is offline   Reply With Quote
Old 01-11-2018, 10:29 PM   #2
triumphleroy
Default Re: 2 Blade Fan
Don't Know about crack in casting but be sure and scrape the Powder Coating out of the taper area that mounts on shaft. I bought 30 model that had a knock that turned out to be the powder coating had flowed out and left fan loose on water pump shaft ate the keyway and shaft up. Previous owner thought it was Timing gear and replaced them, knock was still there so he sold it as is! I replaced Fan and pump quiet as a mouse now.
triumphleroy is offline   Reply With Quote
Old 01-11-2018, 10:34 PM   #3
Flathead
Flathead's Avatar
Talk to Snyder's, if it is defective I'm sure they will make it right.
Flathead is offline   Reply With Quote
Old 01-11-2018, 11:43 PM   #4
daveymc29
daveymc29's Avatar
I've had Snyders fans on several cars I have owned. At one time the advice around town was make sure of the taper before you buy. That problem has been resolved and I have never had a replacement that didn't bolt on and use with no adverse effects. The powder coating issue is easily handled with a pocket knife. In your example, if it were mine I'd get on the phone and find out what they will recommend. They do take care of business in a professional manner.
daveymc29 is offline   Reply With Quote
Old 01-11-2018, 11:56 PM   #5
triumphleroy
I bought another from Snyder and just like Daveymc29 says Pocket Knife will cut that powder coating right out of there! I cut it out with the pocket knife I have been carrying since 1962. The previous owner did not do that though. always good luck with Snyders Parts.
Old 01-11-2018, 11:56 PM   #6
Larry Jenkins
Ask for Tom Jordan. Honest replies..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 01-12-2018, 12:04 AM   #7
Synchro909
Synchro909's Avatar
Cracks in the aluminium casting? Photos will give us something to go on.
Old 01-12-2018, 03:07 AM   #8
old31
I bought a 2 blade recently from Snyders and it was fine. Not sure about your crack.
As synchro says, pictures please.
old31 is offline   Reply With Quote
Old 01-12-2018, 07:36 AM   #9
WHN
I would not take a chance if you think there is a crack in blade.
I have had a fan blade fail while driving. Not pretty. Enjoy.
Old 01-12-2018, 10:20 AM   #10
Lona
Lona's Avatar
Just too many stories about cracked two blade fans breaking and damaging the cars and people. I bought one several years ago from Snyders and some months later noticed a noise thought to be timing gears. Took the cover off and the gears were fine. I noticed a crack in the fan which was about to let loose. Replaced it with a four blade plastic fan and will never go back to the two blade type. Points cars would be another point, however.
Glen
'31 Model A Deluxe Roadster
'31 Chrysler Model 70 Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 01-12-2018, 10:48 AM   #11
Leatherback 57
Old 01-12-2018, 10:56 AM   #12
midgetracer
midgetracer's Avatar
I have used many Aluminum two blade fansfrom Snyders and had no problem, but in this case I would call Snyders. I am sure they will replace it.
midgetracer is offline   Reply With Quote
Old 01-12-2018, 11:34 AM   #13
Fullraceflathead
Fullraceflathead's Avatar
I think that is a parting line flash that didn't get ground off smooth before the powder coating.
I would call Snyder's and return it to be Safe tho.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 01-12-2018, 01:21 PM   #14
Gold Digger
That looks like a crack in the hot die that the fan was cast in to me. I have had lots of experience with the die cast industry since 1969 and to me it looks like a crack in the die it's self and is transferred on to the part or casting from which it came out of. I still would do some investigation.
Gold Digger is offline   Reply With Quote
Old 01-12-2018, 01:32 PM   #15
JOHN CT
JOHN CT's Avatar
Send that picture to snyder’s. They will work with you. I wouldn’t install that on my A. It’s not worth all of the problems you will have if the blade lets go.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 01-12-2018, 02:59 PM   #16
TinCup
TinCup's Avatar
Grind that down and you will only find the casting mark.
TinCup is offline   Reply With Quote
Old 01-13-2018, 04:10 PM   #17
AL in NY
AL in NY's Avatar
If you modify the fan, Snyder's may not take it back. Call them, they'll probably send you a replacement.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-13-2018, 08:18 PM   #18
Synchro909
Synchro909's Avatar
And send this one to me.
Old 01-13-2018, 10:18 PM   #19
henry's 31
Snyder and Mikes are great vendors. If you don't modify it they will replace it for you. Just give them a call. Do not use this one to be on the safe side.
Henry' s 31
henry's 31 is offline   Reply With Quote
