#21 |
I only safety wire the bolts I cant get to after assembly . have never wired motor mount bolts .
V4f |
#22 |
#23 |
Why not safety wire them every 30 years when you rebuild the engine? LOL!
-DAN |
#24 |
This was the wire that was installed on the rear motor mount bolts. I believe it is original. Car had a little more than 49,000 miles.
#25 | |
![]() Quote:
You can really see how fast and sloppy the wire job is. It's exactly as I would expect from Fords line at that time. Nothing like the care and quality that is/was used on aircraft safety wiring. Thanks for posting that.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
#26 | |
Just remember, a reverse S. As one loosens, it will pull on the next.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic |
#27 |
Both those pics are frickin' scary that was factory??
#28 |
My working on SAC bombers forgetting a safety wire and having QC find after
the fact was a NO NO, Ever lost a bolt from the flywheel? Ever lose a bolt from a landing gear/motor mount bolt at 30.000 feet ? I realize it is not exactly the same but.......Henry put these in place for a reason. he didn't drill holes in bolts for weight savings.
Richard in New Bern. When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford |
#29 |
#30 |
I mostly just use the lock washers and have never had a problem .
#31 | |
![]() Quote:
The folks that are still doing the safety wire route seem to be using it for show/points reasons. There is one photo posted in this thread that appears to be a factory original safety wire job...and its not exactly a 'pretty show' job. If I ever were to wire the bolts, I would use that photo as a guide on how to do it. Ironically I think judges would mark a car down for it LOL. Makes me think about Henry and his obsessive policies on cutting cost. There they were, all those guys on the assembly lines putting safety wire on those bolts. It appears that the actual need for wire was never fully assessed or tested by Fords' Engineering department, but rather it was most-likely mandated by Henry himself based on his intuition...this is a sign of a strong leader and intuitive designer, but one who is lacking in disciplined Engineering skills. I hope everyone understands the difference between an 'intuitive engineer', and a 'disciplined engineer'.
#32 |
#33 |
Hi Guys,
Here is a photo of a locking wire twister pliers required to do a neat twist job.
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
#34 |
Safety wire will not stop a fastener from loosening however it will stop it from backing out. From what I have seen safety wiring on T's and A's was not pretty just functional. Take a look at some original Model T ring gear wiring. Many of these have loose bolts when opened up. Time was of importance.
#35 |
I've seen original brass wire holding the magneto bolts on a Model T flywheel. I assume Ford used brass in case it broke or otherwise got damaged, then it wouldn't stick to the magnets.
#36 |
You do not have to make pretty safety wiring. Ford did not have the time for this. Safety wire will not prevent hardware from coming loose but will keep it from falling out.
#37 |
Here are two pictures of the "Factory" installed safety wire on the engine mount bolts from my 53,000 original mile 30 Coupe. I'm 99.9 % certain this engine had never been removed from the car until recently. It still had the original clutch (wagon wheel center). The engine was standard bore, and still retained all the "Ford" script pistons, and valves. Not a very tidy job, then again trying to install the safety wire on a moving assembly line has its challenges.
#38 | |
![]() Quote:
