Old 12-31-2017, 06:17 AM   #1
56yblock
56yblock's Avatar
Default wipers arms
do you know how to remove the wipers arms on 1956 ford ? here's mine look at the pic
56yblock is offline   Reply With Quote
Old 12-31-2017, 06:39 AM   #2
5851a
Default Re: wipers arms
https://www.youtube.com/watch?v=eKvbtxGiI_w Same tool as Lisle 65750 I believe. Most any auto parts store in the small tool section.
5851a is offline   Reply With Quote
Old 12-31-2017, 07:08 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
The wiper arms have a spring-steel retainer on the backside of the arm. You can grab the wiper arm with your hand and squeeze that spring steel retainer while simultaneously prying the base off of the splined stud using a screwdriver. Apply the screwdriver between the top of the nut that holds the bezel to the cowl and the bottom of the wiper arm base. Twist the screwdriver and you will see the base begin to move upward off the stud. Once you get it up a little ways, you can pull it off by hand, but you must have the spring-clip in the back squeezed at all times while removing.
Old 01-01-2018, 03:22 AM   #4
56yblock
56yblock's Avatar
on ebay i saw the wipers arms removal tool for sale
what do you think about that ?
Old 01-01-2018, 11:02 AM   #5
Ole Don
Ole Don's Avatar
A wide blade screw driver is all that is needed.
Ole Don is offline   Reply With Quote
