Old 12-17-2017, 01:15 PM   #1
FrankWest
FrankWest's Avatar
Default letters and numbers stamped on an early block?
Did you ever see letters and numbers stamped on an early block?
FrankWest is offline   Reply With Quote
Old 12-17-2017, 01:33 PM   #2
grumppyoldman
grumppyoldman's Avatar
Default Re: letters and numbers stamped on an early block?
The VIN no. is stamped on the bell housing of my 41 Ford. The floor panel has to be removed to see it. It's pretty high up on the housing, but you can see it. Al
grumppyoldman is offline   Reply With Quote
Old 12-17-2017, 01:36 PM   #3
alanwoodieman
numbers are stamped on the transmission
Old 12-17-2017, 01:42 PM   #4
FrankWest
FrankWest's Avatar
These are not vin numbers...the stampings are
GDI42CAL Stamped in two places along the top of the block
Old 12-17-2017, 03:47 PM   #5
alanwoodieman
most likely production codes--IE day, month, shift, etc
Old 12-18-2017, 07:07 AM   #6
scrapiron
Maybe Job # at a rebuilder...
scrapiron is offline   Reply With Quote
