Old 11-27-2017, 10:25 PM   #6
Tim Ayers
Default Re: Source for '32 Frame blueprint
Originally Posted by DavidG View Post
If you want the real thing, try the Benson Ford Research Center in Dearborn. From what I have seen of the aftermarket drawings, none are complete nor completely accurate.
Thank you, David. Yes, I want the real thing. I've heard the Wescott drawings are off.
I know this will be frowned upon, but we are building a AV8; using a '32 frame. All cross members are original Ford and some tricks thrown in. '26/'27 T rear x member & spring to lower it approx. 2" and a Model A which gets the front down too.
I want to be exact in the measurements and not "close".
