Old 11-24-2017, 01:21 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Default Re: wire gages and rewinding motors
Information for the field coils of the horn:
6 Volt
(1) The 2 field coils are wound in opposite directions.
(2) Original field coil wire is 20 gauge.
(3) a. 45 turns using coated wire.
b. 6 to 7 turns per layer, not perfect is OK
(4) After completing, spray with varnish or epoxy insulating enamel.
12 Volt
(1) Same as above.
(2) Use 24 gauge coated wire.
(3) a. 100 turns
b. 6-7 turns per layer, not perfect is OK
(4) Same as above.
