Old 10-16-2017, 02:14 PM   #1
richsfords
richsfords's Avatar
Default Re: Oil Change Surprise
I changed my fiber gear during a overhaul, because of missing teeth, several oil changes ago and still (ever diminishing) getting few bits of fiber gear in the oil during the change. Also put in a magnetic drain plug to monitor the engine'
good luck
Richard in New Bern.
When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford
richsfords is offline   Reply With Quote
