What's the reason for the large oil pan plug on an ev-8? Is the plug designed for an 'inner" or "outer" box wrench?
Clem |
To drain the oil. (The devil made me do it.)
Believe it was to help remove sludge when oil filters were the exception, rather than the rule.
How? small brush stuck in and wiping around to stir up sludge?
I don't like the big style plug. I find when im draining the oil it comes out far too quickly when you remove the plug and the can ive got to catch the oil gets overwhelmed with the volume of oil that comes out and the oil ends up all over the floor.
Was perhaps the idea that with a large hole in the bottom of the pan you could run a brush around the oil intake filter and clean it off? Is is that a really STUPID idea?
My 226 and some V8's had the big plug and a clean out. I just drained my oil tonight and you are right about oil coming out fast, real fast. Better have the drain pan in the right spot! LOL
So what wrench do you use? Crescent?
When I was in High School in 1950 I worked in a Service Station. when we drained the oil we would removed as much of the sluge we could through the drain hole. Belive we had a special wrench.
#13 |
I use a pipe wrench.
#14 |
I disliked the large plug in my truck so much I welded a bung in the middle of it that uses a modern oil plug with O ring.
#15 |
This is getting to be an interesting thread! Henry always seemed to be messing with the production of plugs: Cast verses stamped. Steering oil plug: stamped steel or cast...
I'm guessing factors in the decision included amount of small scrap pieces Henry had to use, subcontractor issues; extra casting schedule option. Who knows. I thunk I had thing figured today. I have Ford Model T thick sheet metal wrench #1349. It has a large opening for a big nut on one end. Nope not big enough. Packard had a b ox end wrench for mid sizes nuts and the outer edges of the wrench were also shaped to use a an inside wrench used on hub caps and crank opening. I wonder if henry offered a bigger wrench for the large pan nut? |
#16 |
I use a 2 inch open end wrench on that drain plug to drain the oil and a large drain pan to try to cut down on the mess.
#17 |
I have one like this. Bought it years ago, but they pop up a lot.
Its made by Herbrand. No. 2373 |
#18 |
I like this idea. One could still pull the big plug at the end and clean around the pickup. With our modern oils I never see sludge in my engines. The ancient engines I still dismantle now and then contain some serious sludge..
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#19 |
These Kem Tools come on EPay frequently and are reasonable:
#20 |
Back then, every station had a pressed steel wrench with several hex & square sizes on it, including the big FORD size.
