Old 10-03-2017, 04:18 PM   #1
Capt Kirk
Capt Kirk's Avatar
Default Crab distributor ??
Dug through my pile of spares in Fairbanks so I could bring home a few things. This crab was one of them. My car has a helmet so I never really paid much attention to this but now that I have it home, I noticed the bail. Is this right or is it something someone made to hang it?
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 10-03-2017, 05:18 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: Crab distributor ??
Fits, if you're using 1946-48 dist cap set up.
Karl
Karl Wolf is offline   Reply With Quote
Old 10-03-2017, 05:21 PM   #3
Charlie ny
Yours is a post war version....'46 - '48....uses an ugly 2 piece cap. The bail traps the
inner and outer caps. Same dist used with the pre war crab dist cap. Crab cap uses individual clips.
Charlie ny
Old 10-03-2017, 05:25 PM   #4
Tony, NY
I believe you would also use the rotor for the early crab, along with the cap and spring clips.
Tony, NY is offline   Reply With Quote
Old 10-03-2017, 06:52 PM   #5
Capt Kirk
Capt Kirk's Avatar
I did a little snooping and saw the crab with the individual clips. That's why I thought this was something someone did to hang it but the bail didn't exactly look homemade. Does anyone have a picture of what this looks like with the caps on?
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Old 10-03-2017, 07:00 PM   #6
Capt Kirk
Capt Kirk's Avatar
Maybe a bit off topic but I brought back two helmet coils that I had stashed. One has no markings on it and the other has no molded in markings but has a metal sticker that says "Niehoff &Co, Chicago, automotive products, Since 1923". Is there anything special about this coil? I thought about sending both to Skip for rebuild but since I've got a skips coil on my car, I would probably never need them.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Old 10-03-2017, 08:28 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Here's the '46-'48. It's sometimes referred to as "rabbit ears". Note the bail. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-04-2017, 08:53 AM   #8
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Most seem to prefer the crab cap instead of the rabbitt ears one. Its takes a different rotor, two piece cap and the cap index is inside the housing instead of outside as well as the outer bail etc.
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-04-2017, 11:45 AM   #9
40 Deluxe
Niehoff was once a brand of good quality aftermarket electrical parts. Nowadays (if they're still around) they, like many other old-time reliable brands, have been bought by some el gypo company for just their name and are now garbage made to the new owner's cheap standards by an offshore company.
Old 10-04-2017, 12:44 PM   #10
Tim Ayers
I like the look of a crab, but also really like the look of the rabbit ear cap set-up.
Tim Ayers is online now   Reply With Quote
Old 10-04-2017, 02:13 PM   #11
BUBBAS IGNITION
Just some more discussion, i got this from a customer saying the crab cap wouldnt fit????
If ya look really close it never was machined for a crab cap with any external machining and the cap locating pin is internal only.
I have had a few hundred of these in the shop and never seen one like it ????
[email protected]
Old 10-05-2017, 12:05 AM   #12
MGG
MGG's Avatar
I think that the rabbit ear set up is FAR more difficult than any of the other V-8 distributors to install wires in. Compared to the helmet style (in which you have 4 wires in each cap), in the rabbit ears, which is only a little more roomy than a helmet outer cap, you have to cram 9 wires, (8 out to the plugs and 1 in from the coil.) The only thing that saved my bacon was the liberal application of WD-40 to the wires to be able to pull them through. The crab is almost as easy as the top mounted rotary distributer (1949 through 1953) because you have 9 plugs for the wires on the outside of the cap.
MGG is offline   Reply With Quote
Old 10-05-2017, 12:58 AM   #13
RalphM
RalphM's Avatar
Heaven forbid the use of WD-40, it'll stir up a hornets nest around here!
I am in agreement that the later "rabbit ear cap is a PITA, albeit a bit more waterproof and neater installation than the crab cap.
I have yet to hear anyone on here say they use electricians wire lube. We use it at work for wiring trailers and it makes quick work of an arduous task.
RalphM is offline   Reply With Quote
Old 10-05-2017, 04:55 AM   #14
Brian
Brian's Avatar
K Y Jelly works too....[makes quick work of an arduous task!]
Old 10-05-2017, 08:07 AM   #15
BUBBAS IGNITION
Ya think the electricians lube is just wd 40 in a different can??
I went thru the shop and hid all the gallon cans of WD40 after reading this post.....
[email protected]
