Old 09-29-2017, 08:19 PM   #1
trevo
Default Spring Downunder car out for a drive but ??
Got the Roadster out gave it a wash then Wife and I head into the Port for coffee got 2ks slowly lost power switched the auxiliary electric pump on power back to normal same thing every 2k or so had coffee started perfect headed home (around 10 k) same thing every 2k.Have started it up over winter every few weeks, before I begin checking it out any ideas ??
trevo is offline   Reply With Quote
Old 09-30-2017, 07:19 AM   #2
Talkwrench
Talkwrench's Avatar
Default Re: Spring Downunder car out for a drive but ??
What electric pump are you using. Not new is it? Other than that your manual pump sounds like it's knackered..
Old 09-30-2017, 01:27 PM   #3
trevo
The electric pump is only used to prime and start the car if it's been sitting a while normally it starts on the mechanical pump maybe I should look at the mechanical pump first always thought they are pretty reliable thanks
