I agree that vapor lock may be the issue. Fuel filters clogged are also an easy thing to check as well as a tight connection along the exhaust system from manifold gasket to the tail pipe opening.
Hey Rebel, now that is what a parade car should look like. If I saw you go by, I'd have to follow you so I could shake your hand and congratulate you.
