Old 09-03-2017, 09:39 PM   #2
Scottio57
Scottio57's Avatar
Default Re: Preferred Starting procedure
Good sources on YouTube. Make sure you are in neutral. Spark , lever on the left, all the way up. Throttle, lever on the right, cracked open just a little. Gas valve on. Key on. Pull choke and hold. Push starter, after a few turns release choke. Engine should start. Lower spark lever about the 9:00 position.
Scottio57 is offline   Reply With Quote
