Old 08-30-2017, 02:57 PM   #1
Shelbycsx
Default Model T year id
Try to find out what year this model t is. There's a number stamped in the wood BF31818. The motor number isn't legible. Electric starter, metal seat frame, coil box under dash. I'm thinking it's an 18
Shelbycsx is offline   Reply With Quote
Old 08-30-2017, 03:43 PM   #2
pj's junkers
Send a message via Yahoo to pj's junkers
Default Re: Model T year id
What type of number is on the title?
pj's junkers is offline   Reply With Quote
Old 08-30-2017, 03:58 PM   #3
Shelbycsx
No title. It came from an old farm and has a Shaw tractor conversion on it last ran in the 60's.
Old 08-30-2017, 04:03 PM   #4
Shelbycsx
Old 08-30-2017, 04:32 PM   #5
Jack Innes
Jack Innes's Avatar
The cowl is 23 or 24 closed car. There should be a casting date on the same side as the engine number - it will be back & down from the water inlet.
Great looking tractor. Are the front wheels cast iron?
Jack Innes, Brooklin, Ontario
Jack Innes is offline   Reply With Quote
Old 08-30-2017, 04:47 PM   #6
Shelbycsx
Cast iron. I don't see a casting number.
Old 08-30-2017, 06:26 PM   #7
Jack Innes
Jack Innes's Avatar
The casting no. should be about where the one in the picture is. Some later blocks had a round no. insert. The last no. is the year - this one being 1917.
Old 08-30-2017, 09:20 PM   #8
redmodelt
redmodelt's Avatar
They stopped the casting dates around 1922 or so.
Old 08-30-2017, 11:12 PM   #9
Jack Innes
Jack Innes's Avatar
That is good information. It explains whey a casting date cannot be found on the tractor.
It is then possible that the engine fits with the cowl at 23/24.
Old 08-31-2017, 01:38 AM   #10
Dodge
I would say it's a late 23 thru early 25 and yes a coupe or sedan.
Cool project.
Dodge is offline   Reply With Quote
Old 09-17-2017, 09:48 PM   #11
t42
Sometimes the serial number can be brought back by using a liquid dye penetrant used by piping contractors to detect cracks in piping systems. The slightest indentation will show up.
Just a thought.
t42 is offline   Reply With Quote
