Old 08-09-2017, 08:16 PM   #1
RawhideKid
Default Re: Basic advice
Mr.J One thing you can do to help out the over heating is while you have the radiator off the car, simply lay it down flat and pour a gallon of vinegar in it and let it sit a couple days. I have back flushed and even with all that done, after removing the vinegar, I was able to wash out the radiator from the bottom and got quite a few chunks of rust out of it, and this is after a radiator shop did a weekend in the hot tank to clean it!
When you empty the vinegar out, strain it through a cloth and see how much rust comes out. BTW, the vinegar can be used more than once. I don't recommend using vinegar through the engine, because if you don't get it ALL out of the engine, it WILL continue to eat the cast iron!
RawhideKid is offline   Reply With Quote
