Old 08-07-2017, 08:53 PM   #8
1crosscut
1crosscut's Avatar
Default Re: Detergent oil
If you are just going to start it up and let it idle until warm and then change the oil you might be waiting a while for the oil to warm up. That is if you have a cooling system in good order.
In your case I would get a piece of cardboard to cover the radiator to help get it warmed up. Place an inexpensive meat thermometer in the coolant and monitor the water temperature while you are warming it up.
Using the thermometer often while you are getting used to driving your A will give you a lot of information on how your engine is operating. As you get comfortable with it you will use the thermometer less and less.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
