Old 07-24-2017, 11:32 AM   #3
J Franklin
J Franklin's Avatar
Default Re: Out for a short cruise . . .
Put the rear wheels up on jack stands and then remove the spark plugs. Next take the hand crank and if possible turn engine while someone watches and listens for problems. go through the gears while checking and see if you turn up any clues. Good luck and report back with the findings.
