Old 07-09-2017, 04:31 AM   #8
john charlton
john charlton's Avatar
Default Re: front spring shackle replacement? tips tricks or warnings?
Sometimes the perch will not press out of the axle .Sadly in the past I have bent an axle using a 50 ton press (not my press ) Drilling it out would have been the solution .Luckily over the years I have accrued more axles so I don't need to straighten it yet !!! In many perches the bush is worn through and worn into the perch itself . If the damage is not too bad I fit the new bush, cut a slot and MIG this and the exposed bush ends to the perch . This does mean you cannot drive the bush out again but this fix will last way past my lifetime . And also gives the perch an extra lease of life .
John in lovely sunny summers Day Suffolk County England .
