06-29-2017, 07:29 PM | #21 |
Re: Electric fuel pump
I recently installed a Air tex electric pump on my 51 works great when it sits a
week or two I just use it for priming then turn it off |
01-14-2018, 10:54 AM | #22 | |
and where can one find the regulator? thnx alan |
01-14-2018, 07:55 PM | #23 |
I mounted mine on the cross member of my 40 and it feeds back into the uncut original fuel line so I can remove it at any time.
01-15-2018, 02:06 PM | #24 |
I have posted detailed instructions along with photos of how to convert an OEM fuel pump to a pass through, on my thread "What I did on my lunch hour". You'll have to search the thread as I don't remember what page(s) the information is on.
Imagination is more important than knowledge. |
01-21-2018, 08:18 PM | #25 |
Is a electric fuel pump better pushing fuel vs pulling fuel up to the mech pump. I am putting one on my 35 F cpe. thanks Tom
01-21-2018, 09:48 PM | #26 |
01-22-2018, 06:42 AM | #27 |
No matter who’s pump you buy here is the fact
Electric pumps push better than they suck so you always want to mount it as close to the tank as possible . Sent from my iPhone using Tapatalk |
01-22-2018, 07:43 AM | #28 |
Don’t mean to hijack but electric fuel pump running after a crash has always been a concern of mine.
When I rewired the 49 I repurposed a Fuel Pump Inertia Safety Cutoff Switch. FOMOCO has used them for years and put them about anywhere imaginable (under the dash and in the trunk mostly). In the old days I used the run side of the ign switch for pilot duty to a relay feeding a 70s brand X oil pressure switch for run and the Ford starter solenoid ign terminal for startup. |
02-04-2018, 10:26 AM | #29 |
Do you need to use a regulator when using a 12V Airtex pump to prime the engine?
02-04-2018, 08:48 PM | #30 |
No I wouldn't think so , so long as its a low pressure and you don't leave it running...
"Came too close to dying to stop living now!" |
02-05-2018, 12:22 AM | #31 |
I use an Aixtex 12 volt and don't need a regulator. It puts out 3 psi, same as my OE mechanical pump. I use it for pre-start and used it once for driving when I got a vapor lock situation.
02-05-2018, 06:56 AM | #32 |
Great info, thanks guys. Just ordered one from C&G.
