Old 05-28-2017, 10:38 AM   #8
indyward
Default Re: Model A Light Switch
We have a 1928 Model A Sport Coupe. I just redid the light and horn switch and it was working great. High beam at 4 oclock, lo beam at 5 oclock, off at 6 oclock, parking lights at 7 oclock. Horn worked fine. It has a bail holding the switch to the steering column. When you switch the lights on and off several times the bail comes loose, the switch slides down and the switch nor horn work. Anyone know how to get the bail to stay without using a zip tie. Henry Ford didn't have zip ties and I would prefer to not use one either.
indyward is offline   Reply With Quote
