05-02-2017, 07:50 PM | #1 |
Anyone have any experience with Speedometers?
The next problem with the coupe, The speedometer! It was working, then one day after a fast run, I noticed it was still. No speed or mileage.Tonight I crept underneath and took the drive gear off. It is the keyed shaft type. I fitted the cable drive and spun it and it was free. All was OK down below. Topside, I have checked the square drive in the back of the gauge. Everything seems OK. Does this sound like a busted meter? I have a spare, but the numbers need replacing so I haven't swapped them yet. Plus I've been fiddlin' with the running gear and the engine so I haven't devoted much time or effort to the speedometer. I've oiled the bearings that I can get at without disassembly.
Terry |
05-02-2017, 08:29 PM | #2 |
Re: Anyone have any experience with Speedometers?
Sounds like something inside is busted. My first thought was a stripped square drive, but you checked that. I just sent my speedo to Mark Nelson. I don't know yet if he will do a good job, but here is a link to his website:
https://www.marksspeedometer.com/
Joe Minneapolis, MN 1929 Std Coupe |
05-02-2017, 09:44 PM | #3 |
papanick repaired mine...it works great and a quick turnaround...
https://www.fordbarn.com/forum/showthread.php?t=216905
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
05-02-2017, 10:40 PM | #4 |
Papanick. He cares..
Good enough.. Isn't. |
05-03-2017, 01:17 AM | #5 | |
05-03-2017, 07:52 AM | #6 |
05-03-2017, 08:18 AM | #7 |
X5 with papanick. Fast and did beautiful job. Very satisfied!
05-03-2017, 08:33 AM | #8 |
mark will do a good job no worries there
05-03-2017, 08:56 AM | #9 |
That's good to hear. I was getting worried I picked the wrong guy. I will post back here with the results just to close the loop.
05-03-2017, 09:28 AM | #10 |
A minor extra test before you act: One of the little square bits that come in sets approximates speedo drive well enough to work. Give your speedometer a spin with such a bit and an electric screwdriver or drill. That will definitively pin down the problem as speedo or something in drive. And you can very roughly gauge what speedometer reads if you know RPM of the tool, comparing that to the 1000 RPM=60 MPH of the gauge.
05-03-2017, 09:36 AM | #11 | |
05-03-2017, 10:00 AM | #12 |
Forgot to say...be sure it's turning the right way! One way is going to read zero for sure...
05-03-2017, 10:11 AM | #13 |
The way I read your original post it is clear that you ensured the speedometer cable is not binding, but did you check to see if it is broken?
Forgive me if I read your post wrong. Ken
Style beats speed any day, and with a lot fewer tickets. |
05-03-2017, 11:37 AM | #14 |
First make sure your main shaft is not binding. A common problem. You should be able to turn the speedo shaft with your fingers.
05-03-2017, 12:48 PM | #15 |
Make sure that the square drive end on the cable is the correct one for your speedometer, ovals used .124 square, round faced units used .104 square. I am posting a copy of my speedometer notes that I send out to my customers with some info regarding the care and feeding of these instruments.
Mark’s Model A Service, Llc 33691 Finley Point Rd. Polson, MT 59860 Marksspeedometer.com Notes on your rebuilt speedometer 1) Make sure that the end of your speedometer cable is in good condition.If it is rounded on the corners where it goes into the speedometer head, it may slip instead of turning the speedometer. 2) If the instrument is an Oval (28-mid 30), make sure that the end of the cable is .120-.124 square. Make sure that the cable will insert into the speedometer head far enough.The depth of the hole is about 7/16”, but the first 1/8” is round, then it transitions to a square hole.The end of the cable must extend far enough into the head so that it goes at least 3/8” into the input end. The later round units and most other cables are .104 square.They will work for a little while, but will start slipping and round out the drive in the bottom of the speedometer. 3) Now is a good time to inspect and relube the speedometer cable, looking for kinks and places where it is starting to fray. These will catch on the inside of the housing and make the speedometer reading erratic. 4) Make sure that the cable starts squarely into the bottom of the unit; they are easily cross-threaded. 5) There are other factors that affect accuracy other than the speedometer unit. Tire size, rear axle ratio, and drive gear tooth count at the torque tube all make a difference on how the unit will read.I calibrate the units to the standard, which is 1000 revs/mile.If your speedometer is not reading correctly, check the odometer against the mile posts along the highway for several miles, if the odometer is not reading the same as the mileage posts then the cable is not turning 1000 rev/mile.(Most likely the speedometer error will be the same percentage amount in the same direction.) Any question, contact me @ 406-249-3104 Thanks, Mark Nelson
Mark in MT Always looking for another opportunity to be wrong. |
05-03-2017, 01:30 PM | #16 | |
I could just have easily sent it to Mark in Montana as he is much closer....I just didn't see his Swap post first!
05-03-2017, 02:13 PM | #17 |
Hay you can send it to any of us and we will do a good job. One rebuild dose not try to out build a other. But if you do not get it working I will be very happy to make any repairs that are needed. [email protected] I have been doing them for over 20 years.
05-23-2017, 01:25 PM | #18 |
I'm a repeat customer with Papanick. I couldn't be more satisfied. Jr. does it right! I'm sure others would also, but my experience has been with him. Ed in Mississippi
Ed LAW OF MECHANICAL REPAIR ONCE YOUR HANDS BECOME COVERED WITH GREASE,
YOUR NOSE WILL ITCH AND YOU'LL HAVE TO PEE |
