Old 05-20-2017, 06:49 PM   #12
1955cj5
1955cj5's Avatar
Default Re: Rear spring
Good Work!
When I put mine back together I used some graphite spray between the leaves...
That made it pretty "springy" when hitting small bumps or low spots going through intersections.
I finally put shocks on.
The shocks were planned anyway but the fewer leaves( from 13 to 8) and lubricated spring made them happen a little sooner..I may put a leaf back someday...
This is what I used. It dries almost immediately.
There are other similar products..Slip Plate is one...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
