I had a similar problem. I found that while I was double clutching for first to second, I would move the shifter from right to left (in the middle) a couple of times, and then go to second.
It only happened from first to second. It has since worked itself out. I think mine was a little corrosion on the rails, from years of sitting. Good Luck;
Brian French; 1930 Briggs Town Sedan |
