Old 05-14-2017, 09:12 AM   #6
Dick Steinkamp
Dick Steinkamp's Avatar
Default Re: Can not shift to 2nd or 3rd gear
If you can shift the car into low and/or reverse with the engine running and the clutch depressed, it's not the clutch or related clutch parts. The clutch may need some attention, but it wouldn't be keeping you from shifting into 2nd and 3rd.
I'd pull the shift tower off and check it for broken, missing parts.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
