Old 05-13-2017, 08:19 PM   #1
fordlovr
fordlovr's Avatar
Default HELP! Brake I.D. Please
Can any please tell me what year these are? been in the shed for so long i cant remember where i got them from!
fordlovr is offline   Reply With Quote
Old 05-14-2017, 02:44 AM   #2
Brian
Brian's Avatar
Default Re: HELP! Brake I.D. Please
Dunno the first one [maybe Pilot?], but the other two photos are 35-36 Ford
Old 05-14-2017, 04:02 AM   #3
Mart
Mart's Avatar
The first one is Ford Pilot. Or at least the same as on a Pilot. It looks like the front pilot brakes I have seen, with the transfer levers and pushrods to make it like a twin leading shoe setup. BUT! I only thought that setup was used on the front. That does look like it is on a rear axle casing.
Front Pilot brakes are operated by a cylinder that bolts on the back of the front backplate. Rears are operated directly by a cable (I think, either a cable or rod - not hydraulic).
Not sure on the second one, except that it is a mechanical pushrod type, meaning it was used on the front. The third looks like a rear mechanical type.
Mart.
Old 05-14-2017, 06:16 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Never saw anything like that one in the first picture. The second looks like a rear '35-'36 Ford backing plate, and the third looks to be a rear '36 Ford backing plate because the lower brake shoe pivot is riveted in place rather than bolted in place.
John
