Old 05-08-2017, 08:23 PM   #4
larrys40
Default Re: KR Wilson hub puller
Ian
The protruding ring was 28 and if that's the case it will not work.
There's a flip top clam shell type that I ligt from industro of the era.
U don't like the ones that go on the studs as they can distort the hub and drum although you might not have any alternative .
The suppliers also sell a 28 cast puller which should work as well
Ill try and post some photos later
Larry
larrys40 is offline   Reply With Quote
