Old 04-28-2017, 07:46 PM   #1
KEN2939
Default No spark
just got a 29 A, looking to add a1931. the car I'm looking at has no spark. any thoughts what I should look for first.
KEN2939 is offline   Reply With Quote
Old 04-28-2017, 08:08 PM   #2
Charlie Stephens
Default Re: No spark
What is the last thing(s) they did before the problem started? A friend's no spark problem turned out to be the points were so wide that they weren't closing.
Charlie Stephens
Old 04-28-2017, 08:20 PM   #3
Jacksonlll
Jacksonlll's Avatar
As long as the distributor rotor turns when the engine turns, don't worry about it. Easy to fix.
Old 04-28-2017, 08:52 PM   #4
Art Newland
Art Newland's Avatar
If it's been a while since run, run a business card or matchbook cover (or similar) between the points, might be oxidized.
Art Newland is offline   Reply With Quote
Old 04-28-2017, 10:43 PM   #5
KEN2939
as always thanks for the suggestions and help.
Old 04-28-2017, 11:18 PM   #6
H. L. Chauvin
Hi Ken,
Per your question:
"the car I'm looking at has no spark. any thoughts what I should look for first."
You could bounce around testing connections etc., for weeks on end; or,
First? Check the battery and the battery ground.
Second? Obtain a wiring diagram to check (+) & (-) electrical continuity from the battery to the spark plugs.
Relieves depression, headaches, acid indigestion, & ends sleepless nights.
H. L. Chauvin is offline   Reply With Quote
Old 04-29-2017, 12:22 AM   #7
Mike V. Florida
Mike V. Florida's Avatar
If it spins be careful. If you get it started before you buy it the price could go up. You have leverage now.
Come back once you buy it, we will give you step by step instructions to get it working.
Old 04-29-2017, 12:50 AM   #8
Beauford
Mike...sounds like you have done this before??? HAHAHAHAHA
Beauford is offline   Reply With Quote
Old 04-29-2017, 12:56 AM   #9
Synchro909
Synchro909's Avatar
My thoughts eggzackery.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 07-29-2017, 08:51 PM   #10
CB919ER
CB919ER's Avatar
I'm facing a similar problem. I spent all day flushing the tank, changed the plugs, put my freshly cleaned carb on the car and it won't start. Has a new battery and turns over strong as can be, but it won't catch and run, I cleaned between the points and I pulled a plug while I hit the starter I had a friend watch for spark. She said there wasn't any. I'm open to suggestions
CB919ER is offline   Reply With Quote
Old 07-29-2017, 09:06 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Key one, engine stopped with points open, short the points contacts on and off with a screwdriver and see if the coil wire has a hot blue spark at least 1/4" long to a head nut.
Old 07-29-2017, 09:35 PM   #12
CB919ER
CB919ER's Avatar
I want to know what all that means, but I only sort of understand
Old 07-29-2017, 09:52 PM   #13
1955cj5
1955cj5's Avatar
First he meant ignition key ON...with the engine NOT running
Then take the cap off the distributor and make sure the point contacts are open....
Use a screwdriver to short across the contacts on the points, this simulates what happens when the engine is running..
The points, by opening and closing, very basically cause the coil to produce enough voltage to make the spark plugs spark.
With the large center wire from the coil held(use gloves) about 3/8" from a good ground like a head stud, you should see a hot blue spark as you repeatedly short the points with the screw driver....
If you have a spark using this method then the issue could be timing or maybe corroded point contacts or even too much or too little point gap.....there are other possibilities too...let us know what you learn...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 07-29-2017, 11:21 PM   #14
mike657894
mike657894's Avatar
get a test light or meter and test for voltage at the coil, key, and distributor. common problems I have dealt with are bad coil bad switch and bad cable to dizzy also clean the points up.
mike657894 is offline   Reply With Quote
Old 07-29-2017, 11:50 PM   #15
Mike V. Florida
look here
https://www.fordbarn.com/forum/showpo...09&postcount=4
and the same thing worded differently,
https://www.fordbarn.com/forum/showpo...87&postcount=4
Old 07-30-2017, 10:00 AM   #16
wmws
Mike V.
I liked your no spark troubleshooting guide very much. Very clear and understandable. However the last sentence says, "Remove the paper from the points and see that the points are closed. You should not have 0 volts at the points." Did you mean to say you should have 0 volts?
wmws is offline   Reply With Quote
Old 07-30-2017, 10:34 AM   #17
CB919ER
CB919ER's Avatar
Anyone in Chattanooga want to help me???
Old 07-30-2017, 11:38 AM   #18
CB919ER
CB919ER's Avatar
Ok, followed the directions as best I could, points open, used a screw driver across the point (got a little spark here) and put the wire from the distributor near a head bolt and I got no spark. I have power to the points and on both legs of the coil, but nothing through the line to the distributor...
Old 07-30-2017, 11:44 AM   #19
mike657894
mike657894's Avatar
if its really troubling you spend about two hundred and replace all parts. I would go with buying a 10$ meter though. You dont need a meter to repair the model A ignition but it takes a
lot of the guess work out of it.
Old 07-30-2017, 11:46 AM   #20
CB919ER
CB919ER's Avatar
I have a volt meter and a Circuit tester but I don't know what to check.
