View Poll Results: which ohv head work best
test 4 80.00%
test 1 20.00%
Voters: 5. You may not vote on this poll
Old 01-17-2011, 10:36 PM   #1
john greco
Default hello guys which ohv unit works best , crager riley ? ?
which ohv head works the best as far as drivability ? horespower ? are the new ones any good ? what cam and carbs work the best with this conversion ? does anyone know of any for sale ?
john greco is offline   Reply With Quote
Old 01-17-2011, 10:42 PM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: hello guys which ohv unit works best , crager riley ? ?
http://www.secretsofspeed.com/RILEY.htm
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-18-2011, 09:33 PM   #3
redmodelt
redmodelt's Avatar
The free one!
Old 01-19-2011, 12:15 AM   #4
hotrodalley
hotrodalley's Avatar
steve serr crager
hotrodalley is offline   Reply With Quote
Old 01-19-2011, 01:17 AM   #5
Crazydaddyo
Crazydaddyo's Avatar
Originally Posted by hotrodalley View Post
steve serr crager
^^^^^^^ What he said. ^^^^^^^^
Crazydaddyo is offline   Reply With Quote
Old 01-19-2011, 07:10 AM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
John, in thinking about your question(s) over the past couple of days, ...how many people have actually owned both heads, --either as the originals or reproductions to be able to give you unbiased feedback regarding comparisons? While I am not a fan of "Yapp Krapp", his repro F head was a great trend setter because of some modifications he made to it to improve drivability of the more stock-type L-head engine. I own (and have owned) several banger OH valve heads (including a Steve Serr Miller) and each has there own characteristics and strengths IMO. I am also of the opinion that knowing the best camshaft, induction, drivability etc. are all determined when one knows whether the combination will be installed in a Speedster, a Roadster, or a 4-door Sedan, ...and whether "driveability" means 'stop light to stop light', or countryside touring.
As far as other's for sale, unless you are a machinist and have the ability to repair original units, I would suggest you look towards new ones. Steve Serr and Dan Price both make nice units. Since I have raced bangers with Dan and know him personally, I also know that he has other "more unique" heads for sale that might interest you however I would tend to say that some of his would lean more towards being a racing head than what a repro 2P head might be on the street. I hope this helps you some.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-19-2011, 09:32 AM   #7
George Miller
George Miller's Avatar
I think Brent has it right. It all depends on the combination of things. You have to have it all. To much camshaft will kill them to much carb will kill them for the street.
George Miller is offline   Reply With Quote
Old 01-19-2011, 11:55 AM   #8
just plain bill
just plain bill's Avatar
It is kinda like sex, all are good but some better.
It takes more than just bolting on a "Gee Whiz" head and buying a cam that is recommended by some one as being the best, bolting on a pair of Strombergs and installing the latest "bells and whistle" ignition. I don't use radical cams and I try to hold the compression under 8 to 1. I have set up the Miller/Cragar type OHV but have had better results with the F head in my car. Admittedly, I haven't had any experience with the Miller High Speed or the Dan Price unit. Both are well engineered and tested. To me, in my humble opinion, the proof is in the results not in the magazine articles.
just plain bill is offline   Reply With Quote
Old 01-19-2011, 12:02 PM   #9
BRENT in 10-uh-C
It takes more than just bolting on a "Gee Whiz" head and buying a cam that is recommended by some one as being the best, bolting on a pair of Strombergs and installing the latest "bells and whistle" ignition. I don't use radical cams and I try to hold the compression under 8 to 1. I have set up the Miller type OHV but have had better results with the F head in my car. Admittedly, I haven't had any experience with the Miller High Speed or the Dan Price unit. Both are well engineered and tested. To me, in my humble opinion, the proof is in the results not in the magazine articles.
BRENT in 10-uh-C
Old 01-19-2011, 12:48 PM   #10
Jim Brierley
Brent in 10-uh-C covered it nicely. There is an old adage, "if you want to race, get a Cragar, if you want to win, get a Riley" Having said that the 4-port Riley is by far the best performer, then the Serr Miller, followed by the 2-port Riley. I own and run 4-ports and an early Miller, and have owned and ran a 2-port many years ago.
Old 01-19-2011, 01:28 PM   #11
82ndscotty
love my serr miller on . m13 cam, single 94 carb ,30 coupe. scotty
82ndscotty is offline   Reply With Quote
Old 01-19-2011, 03:10 PM   #12
hardtimes
hardtimes's Avatar
John,
There are many different OHV setups to be had, and you can select one, depending on how fast/how much money you want to spend to go fast. I know some great model A/B guys that have collections of OHV 'stuff' , including many complete running OHV setups. None for sale, as collectors don't sell..they collect!
My opinion..there is a great variety of flathead heads that will give less grief, cost less(BY THOUSANDS) and that you can readily get info/help with. Sure there are a couple groups whose members seem to run OHV setups, but unless you live next to such member who will share experience/knowledge...it's a trial/error thing, I've found. Very expensive way to learn with OHV. When you add cams/carbs/intakes/ exhaust/distributors,etc...into your question, now you've upped the $ input substantially! As to 'which is best', everyone has an opinion of what they have or run and, of course, there's the builders opinions.
My opinion...google: "Frick". That guy's creations have always amazed me!
Old 01-19-2011, 07:53 PM   #13
Flathead
Flathead's Avatar
God Bless the Flatheads. Oh wait, that wasn't the question.
Flathead is offline   Reply With Quote
Old 01-19-2011, 11:05 PM   #14
sturgis 39
The Yapp Riley is not aluminum. He also is producing the roof head.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 01-20-2011, 07:49 AM   #15
BRENT in 10-uh-C
I don't believe anyone said it was, did they?
BRENT in 10-uh-C
Old 01-20-2011, 08:31 AM   #16
sturgis 39
Cool Re: hello guys which ohv unit works best , crager riley ? ?
Brent
I was lucky to get out of spell check with the word "aluminum". I think that most of the rest are aluminum but I am not sure. I am also not sure whether the correct term is cast iron or cast steel. The Yapp Roof head is not aluminum.
Old 01-20-2011, 12:07 PM   #17
BRENT in 10-uh-C
Brent
Ohh, ...OK
Just curious since you mentioned it, do you think having a steel head vs. an aluminum head is an advantage, --or disadvantage in this application?
BRENT in 10-uh-C
Old 01-20-2011, 12:35 PM   #18
sturgis 39
Ohh, ...OK
Brent
I like steel head because coefficient of expansion is the same as the block. Keeps the head gasket from moving. That is the only advantage. I would not be afraid of buying an aluminum head.
Old 01-20-2011, 02:01 PM   #19
just plain bill
In 2008 my 1500 lb. car with a Riley 2 port ran 84 MPH at the Antique Nationals. (This past year it ran 82 with a Winfield head) I don't remember hearing how fast the Miller/ Cragar equipped cars ran. If I'm correct the fastest one this past year was 78 or something like that
Old 01-20-2011, 10:54 PM   #20
CWPASADENA
CWPASADENA's Avatar
Brent
I agree,
If you are going to put something together and do not want to take it apart for a long time, I think you have better luck running a Cast Iron Head. That said, there is supposed to be gaskets available that eliminate part of the problem of things expending at different rates. However, if I had my choice, I still like a Cast Iron Head with a Cast Iron Block.
Just my opinion,
Chris
CWPASADENA is offline   Reply With Quote
