For a 1950 Ford.Is there a tool to hold the yoke when adjusting the yoke nut in the car? Ir so what does it look like when adjusting it in the car?
Thanks |
When you say 'adjusting the yoke nut', do you mean torqueing it down tight?
I took a 18" length of 3/16" thick steel, approx. 1 1/2" wide, drilled two holes along one edge (to bolt to two holes in the flange) and ground a notch along the edge between the two holes so a socket would fit on the yoke nut. I can take a photo if it will help. ...Terry |
The term yoke has a fairly broad meaning. What particular yoke are we referring to?
Rotorwrench, my first thought was the yoke on the differential, but you are right, we should wait for more details.
...Terry |
Yes. The yoke on the differential. I have a pinion noise. Figured I would check out that before taking the car into a shop. It a 1950 Ford.
Bill |
If it is in the car then I use the emergency brake to hold it. If you have bearing issues then the whole thing will need to be taken apart. If you're just replacing a seal then mark the nut position and tighten back to the same spot.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
Ford did have a tool for that purpose. It was a 3 foot flat bar with a rectangular end. At the end it had a hole in the center to get a socket thru and 4 holes so you could bolt it directly to the rear end yoke. I used it many times in the 70's when I was a Ford mechanic.
Barry 50 F-1 |
Yes...I have one of those, holed at both ends to fit various patterns. Get a stout piece of angle iron and make one up!
Mine is a piece of angle iron with a slot cut into it large enough for a socket to fit around.
I have a Kent Moore pinion holding tool J-8614-1 that works great on all makes although it was made for GM products there are also additional pieces ( J-8614-2 and J-8614-3) that allow it to be used a pinion yoke puller.
https://www.picclickimg.com/d/w1600/...er-Remover.jpg Regards, Brian |
