Old 04-16-2017, 10:18 AM   #1
Patrick L.
Patrick L.'s Avatar
Default Re: Help needed: Fuel Flow issue
Its common for the sediment bowl to not fill until the air is bled from it. The fuel should then flow freely. If it doesn't then is another issue to contend with. Try opening the fuel cap to see if that helps. If not, then it time to look at the tank and its fittings.
Old 04-16-2017, 03:43 PM   #2
Mitch//pa
What patrick said its normal for it to air lock from opening it..(self inflicted))... u need to do a proper diagnosis
