Old 04-16-2017, 10:12 AM   #1
Dave in MD
Default Re: Help needed: Fuel Flow issue
Jason,
Happy Easter to you.
There might be a pencil filter on top of the shut off valve inside of the gas tank that is completely or partially clogged. A quick but not permanent fix is to blow air back through the gas line with the valve open. Let us know what you find.
Dave
Dave in MD is offline   Reply With Quote
Old 04-16-2017, 06:34 PM   #2
Dick Steinkamp
Dick Steinkamp's Avatar
Dave
Originally Posted by Dick M View Post
Check gas line from the sediment bowl to the carb. The gas line on both ends should not be more than 1/8" past the ferrule. Any further and you risk restricting the gas flow.
The OP posts...
"when I loosened the bowl screw to the point that it almost leaked on the outside, it would flow smoothly and rush to fill the bowl and the car would run fine for about 10-15 minutes."
It doesn't sound to me like any sort of blockage in the fuel delivery system.
I'm going with the gas cap suggestion.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
