I used vinegar and let it sit a month, then back flushed the block only, then the radiator only. Lots of rust came out and I refilled with water and a cup of baking soda. Ran it a day or two and repeated the flushing, then did it again. After the third flushing I filled the works with 50/50 antifreeze. I also installed a 160 degree thermostat in the upper hose, just above the water pump. (S0 far it hasn't moved) I had soldered the stat to a rolled piece of copper that I had made into a 1.5 inch pipe just barely able to pound into the hose. Seems to be working fine and so far no rust appearing in the antifreeze.Temperature after running a half hour or so is slightly higher than it was without the thermostat, but just about 180 in the upper hose above the thermostat. Usually 165 on the lower hose.
