Old 04-06-2017, 10:01 AM   #1
Jason in TX
Jason in TX's Avatar
Default Re: HELP: ready to start again...n/g
Sounds like you have gas and spark. Air is a given.
Take the distributor cap off. When you crank the car, does the rotor spin? I've had the oil pump gear break after a car sat for a while and while all conditions seemed perfect, The distributor rotor wasn't spinning.
This is down at the bottom of the distributor shaft and has a pin in it that can sheer.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 04-06-2017, 10:11 AM   #2
gypsycandle
gypsycandle's Avatar
thanks didn't check that but i will now...
I'm quickly becoming a "Specialist" in which I know more and more about less and less until I know everything about Nothing!
gypsycandle is offline   Reply With Quote
Old 04-06-2017, 10:58 AM   #3
gypsycandle
Yes the rotor turns completely around..
