Go Back   The Ford Barn > The Swap Meet > For Sale > Late V8
Old 01-17-2011, 07:30 PM   #1
RICHIES
Default RICHIES scoops finned,aluminum
City: clackamas
State: oregon
Price: $95.00
Up for sale is a (one) Polished nostalgic vintage scoop for your hot rod,gasser,rat rod car. This scoop will fit any 5 1/8 carb throt but you may need a adaptor for it which are readily available. The scoop measures 7 3/4 inches across from side to side in front and is aprox 6 1/8 from front to back measured on top. bottom is about a 1/4 inch longer bacause the bottom lip sticks out a bit on bottom. It is aprox 2 7/8 inches tall from bottom to top of finn.There are 13 finns on the top. The mouth is 7 3/8 wide by 1 3/4 tall. It has three places that are drilled and tapped for set screws.I do have these in as cast also and have adaptors for them also. Price for polished is $95.00 plus shipping and handling and for as cast is $70.00 plus shipping and handling.
RICHIES is offline   Reply With Quote
Old 07-18-2012, 12:56 PM   #2
rickwlsg363
Default Re: RICHIES scoops finned,aluminum
do you have more than one or do you have a pair of polished ?
rickwlsg363 is offline   Reply With Quote
Old 07-18-2012, 11:46 PM   #3
RICHIES
Hi, thanks for the interest. Wow been along time since I have been on here more then likely a yr or so. As far as the scoop I am not sure if I have a pair of those polished or not.I will check and see. I do have some other scoops and stuff I make now. Send me a email and i will send some pics of them all.In the mean time I will check for two polished ones. Thanks again. burt "RICHIES"
