Old 03-09-2017, 09:37 AM   #1
jake197000
Default lincoln v-12 cam
cant seem to find much info on this.want to do a mild built on a 41 linc v-12.how do they respond to a cam ?done quite a few v-12 but only stock.
jake197000 is offline   Reply With Quote
Old 03-09-2017, 10:08 AM   #2
41PICUP
41PICUP's Avatar
Default Re: lincoln v-12 cam
Check with the people at H&H Flatheads
41PICUP is offline   Reply With Quote
Old 03-09-2017, 10:19 AM   #3
JWL
If for street they can't get out of their own way with a performance cam.
JWL is offline   Reply With Quote
Old 03-09-2017, 10:22 AM   #4
Ol' Ron
Ol' Ron's Avatar
I've always wanted to run an L-100 in a Lincoln V12, However the cam needs some compression to preform well in a V8. But the sound would be in-creadacle.
Old 03-09-2017, 10:22 AM   #5
Bruce Lancaster
I think this is the book you need...I'll have to check at home to be sure:
Ocee Ritch, the Lincoln Continental...if that's the right book (fairly easy to find online) it has a set of dyno tests on a mildly hopped H V-12 and even tosses in a reprint of the Ford overhaul book.
Old 03-09-2017, 11:07 AM   #6
jake197000
I think I have a copy of that book.ill see if I can find it.i take it the linc.likes a bit more compression.might try dual straight pipes also.just for the sound.
