Old 02-27-2017, 07:11 PM   #10
Art Newland
Art Newland's Avatar
Default Re: Reproduction Pressure Plate
Originally Posted by James Rogers View Post
When you are into the clutch and having work done, I have never understood why anyone wouldn't just install a V8 setup. Cost is 450$ and you will spend almost that much to re-furb the stock setup to the same place and still have an extra 17-20# on the rear main.
Why do they say you have to use a balanced crank if you lighten the flywheel?
Art Newland is offline   Reply With Quote
